No access to menu only info screen
sh_prusa
(@sh_prusa)
Hello,
PRINTER: PRUSA i3 MK3
1. After a damage on the thermistor cable I got a MINTEMP Error on the LCD
2. I replaced the hotend with a new(not original) one
3. Now I don't have access to the menu, only at the INFO Screen. Nothing happens when I rotate the rotary button. Only when I push the rotary button I get the Z coordinate but nothing reacts...
Any suggestion or hints much appreciated.
Posted : 23/11/2023 12:46 pm
Robin_13
(@robin_13)
RE: No access to menu only info screen
Sounds like something is plugged in wrong.  Check that all connections are in the correct spot.  It is easy to make that mistake.
Posted : 26/11/2023 5:18 am
