Newbie question
Desert
(@desert-2)
Newbie question
At the end of printing the printhead stops very low above the printbed at the left side.
Is there a way (menu?) to move the printhead up so it easier to clean the nozzle and remove the steel-bed without touching the printhead?
Este debate ha sido modificado el hace 5 years por Desert
Respondido : 02/09/2021 9:47 am
Press and hold the LCD Control button for a couple of seconds, and you should go right to the Z height adjustment
Respondido : 02/09/2021 5:10 pm
1 les gusta
Desert
(@desert-2)
Many thanks.
That's what I was looking for!
Respondido : 03/09/2021 7:54 am
one of those situations where it's right in front of your nose, but not obviously visible.
Happy printing!
Joan
Respondido : 03/09/2021 10:22 am
Or you can change the End G-code of your printer profile. You have to be in expert mode in Prusaslicer to see it under Printer Settings/Custom G-code.
Look for a line similar to
{if max_layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+30, max_print_height)}{endif} ; Move print head up
Change the 30 to whatever value you like. I have set mine to 50, which moves it high enough to clean the nozzle.
{if max_layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+30, max_print_height)} F720 ; Move print head further up{endif}
Respondido : 03/09/2021 11:35 am
1 les gusta
Desert
(@desert-2)
RE: Thanks fuchsr
I come from the time when Madness had a hit called One Step Beyond.
So I'll just do that. 😀
Esta publicación ha sido modificada el hace 5 years 3 veces por Desert
Respondido : 03/09/2021 11:45 am
