New SuperPINDA on MK3S
Oleshc
(@oleshc)
My MK3S' PINDA suddenly died for no reason so printer can't print at all (self test fails, Z calibration fails when head reaches top).
So I ordered MK3S to MK3S+ upgrade kit because it also contains new PINDA.
However the kit requires to print the parts first so I can't do the upgrade.
I was wondering, will firmare work correctly if I replace only PINDA first and then try to print the parts for the remaining upgrade? Maybe it works differently with MK3S+ than with MK3S and it will assume + when it sees new PINDA...
Opublikowany : 20/10/2021 3:28 pm
K7ZPJ
(@k7zpj)
Installing SuperPINDA only works
Replacing the just the super pinda works fine with no issues.
The recommendation for the MK3S to MK3S+ upgrade was not to do it unless you printer has issues printing because you won't gain any printing improvements.
Unless you were having other printing problems,  I would install the super pinda, make sure you have the current firmware installed and print the upgrade parts for future use.
I wouldn't install them until you have to do other issues with the printer that require taking it apart.
Opublikowany : 20/10/2021 3:57 pm
You can just replace the SuperPinda, then print whatever parts you want to print. I didn't bother with the x axis and y axis upgrades as everything was working fine. I did do the extruder upgrade though.
Opublikowany : 20/10/2021 4:00 pm
