New nozzle (0.25) and prints are failing randomly
Nielscorn
(@nielscorn)
Hello
I've recently changed the nozzle from the standard 0.4mm to the 0.25 nozzle.
i'm using the Prusa MK3 (not using the new MK3S).
I'm trying to print a 3D coin (2 halves that I can push together (1 side has a little hole and the other one a pin so they can be pushed together).
It seemed to be going great but it randomly doesn't extrude or brings in filament for some reason and then prints fine again, it also suddenly happens after a while and sometimes right in the beginning. It's incredibly frustrating and i have no idea how to fix this.
On the bed:
On the bed (topdown view):
On the table(1st layer back):
Close up:
Close up 2:
Coins in PrusaControl Top view:
Coins in PrusaControl Down view:
Could someone help me? Should I change anything from settings?
EDIT:
I've been trying it with the boat test print with the 0.25 slic3r settings:
Picture 1:
Picture 2:
Napsal : 28/02/2019 11:12 am
Re: New nozzle (0.25) and prints are failing randomly
Pretty filament... but not what you want to use with a 0.25 nozzle. I can even see flakes as large as the nozzle diameter in the prints.
Load a non-glitter-filled filament, do a few cold pulls to try to remove the glitter particles plugging the nozzle. Then print only non-filled filaments with the 0.25 mm nozzle.
Napsal : 02/03/2019 5:09 am
Martin Wolfe
(@martin-wolfe)
Another thing to watch out for with a 0.25mm nozzle is your extrusion multiplier. For PETG on my 0.4mm nozzle I was using 0.99 and on the 0.25mm Micro-Swiss I use 1.21.
Regards,
Martin
Martin Wolfe
Napsal : 02/03/2019 2:23 pm
