new i3 MK3 can't load filament completely
zach.j
(@zach-j)
I've just finished putting together my i3 MK3 kit, all the parts seem to be installed correctly and running, and the preflight checks all went well up until I loaded filament. There's some kind of blockage inside the hot end assembly that I can't fix. The filament loads up to around 1/2"-3/8" from the extruder tip and then the idler clicks over and it can't get any farther. When I unload the filament it hasn't even started melting at the end. The hot end is definitely getting hot enough to melt the PLA though, when you take a piece and put it against the outside of the tip it will start to melt. Is my hot end defective? Am I doing something wrong? Any help would be appreciated. Thank you!
Napsal : 01/02/2019 3:37 pm
Re: new i3 MK3 can't load filament completely
There's a known issue of the gear idler shaft being too short and coming loose on one end. Search for the thread that has the video showing the problem and solution.
Napsal : 02/02/2019 8:51 pm
have you cut the end of the filament at an angle?
if you don't the end of the filament can catch on the end of the heatbreak
Joan
Napsal : 02/02/2019 10:33 pm
