New Firmware Version Available
Bruster999
(@bruster999)
Is there a way to turn off the firmware update prompts (please don't advise me to upgrade) on my MK3? I will eventually upgrade but for now I would like to turn off the prompt. Thanks.
Opublikowany : 30/03/2022 8:39 pm
Not from within Prusa Slicer afaIk. Your best method would be to deny PS any access to the web so it never finds out.
Opublikowany : 31/03/2022 12:18 am
ejberg
(@ejberg)
RE: New Firmware Version Available
In the slicer, go to "Printer Settings" - "Custom G-code" - "Start G-code", and remove the line starting with M115.
Save the printer settings (under a new name), and that should be it. All print jobs sliced with these modified printer settings, shouldn't nag you with firmware updates anymore.
Opublikowany : 31/03/2022 6:15 am
Bruster999
(@bruster999)
Worked perfectly. Thank you!
Opublikowany : 31/03/2022 12:30 pm
Well I never ... So that's what that does ... there's always more to learn.
Opublikowany : 31/03/2022 2:49 pm
