New firmware = Loud beep when powering off - even in mute.
Mike
 Mike
(@mike-66)
Ever since I updated to the latest firmware it seem the print refuses to mute the beep for power off.  Is there anything we can do to fix this behavior? I have tried silent and mute.. but still has the loud beeps.
Napsal : 13/07/2019 3:15 am
sin
 sin
(@sin)
RE: New firmware = Loud beep when powering off - even in mute.
I don't have a fix but I wanted to confirm that mine is doing this too after flashing 3.7.2. Didn't before. Possibly power panic related?
Napsal : 13/07/2019 5:02 am
Smudo
(@smudo)
Same here, that's really annoying.
Napsal : 15/07/2019 11:52 am
Strasni
(@strasni)
That beep is realy anoying. alway when powering the printer of. Any way to shut it down? remove/block the speaker?
Prusa give us the mute profile back!!
Napsal : 15/07/2019 8:02 pm
Mike
 Mike
(@mike-66)
Well at least I'm not the only one!
Napsal : 16/07/2019 3:49 am
dkeipp
(@dkeipp)
Hello!
at the moment I can not tell if its the same at my printer.. But you can put a piece of tape on the beeper (there is a hole on top of it, just cover it with something sticky) That should make the beeper much more quiet.
Napsal : 16/07/2019 4:33 am
dkeipp
(@dkeipp)
look here:
https://github.com/prusa3d/Prusa-Firmware/issues/1929
it looks like you powering off the printer with a switched outlet or similar and then the powerpanic is triggered. Try the tape workaround from above until FW3.7.3 😉
Napsal : 16/07/2019 12:07 pm
Texy
 Texy
(@texy)
..I'm too busy printing to switch it off 😀
Napsal : 16/07/2019 12:57 pm
1 lidem se líbí
Mike
 Mike
(@mike-66)
no I'm using the switch on the back of the printer.. but it looks like others have the same issue.
maybe a fix in 8.3
Napsal : 17/07/2019 5:09 pm
Trev
 Trev
(@trev)
I reverted to an earlier firmware issue but the wretched beep came with it AND the heaters which had stopped working with 3.7.2 still fail to work.
Napsal : 17/07/2019 8:57 pm
