new build issue
ShuhDonk
(@shuhdonk)
new build issue
Just built my mk3s (This is not my first mk3s).  It is all together, pretty sure everything is wired properly, I triple checked everything but when I power it on all I get on the screen is blue, lights up blue but nothing else.  I tried connecting to the printer via usb to flash the board but would not connect.  But if I disconnect the lcd screen cables and power it on I was able to connect and flash the board with latest firmware via prusaslicer.  When hooking the screen back up I get the same results, just blue lit up screen and nothing else.  ideas what to check for?  Thanks!
Napsal : 05/03/2021 1:42 am
Dan Rogers
(@dan-rogers)
RE: new build issue
The "where to plug in" pictures are very hard to see. There are a couple of wire connections that could go one pin over, one slot over.  Look at the pictures VERY CAREFULLY to be sure you are plugging them in correctly.
Napsal : 05/03/2021 4:51 pm
ShuhDonk
(@shuhdonk)
RE: new build issue
@dan-rogers
I will check again but I even unplugged everything (except power and the screen) and still got the same results :/
Napsal : 05/03/2021 4:53 pm
Dan Rogers
(@dan-rogers)
RE: new build issue
It might be time to move over to the e-shop and use the support feature.  While there are prusa dudes lurking here, the new product support is via chat feature on the e-shop.
Napsal : 05/03/2021 4:55 pm
1 lidem se líbí
