Neosanding / ironing in Slic3r PE ?
3DALHEMIJA
(@3dalhemija)
Option equivalent to Cura's ironing (every top layer) in Slic3r PE?
Respondido : 05/02/2019 8:26 pm
Re: Neosanding / ironing in Slic3r PE ?
Question you have?
Respondido : 06/02/2019 1:19 am
rob.l6
(@rob-l6)
He obviously wants to know if that feature is present in Slic3r. Answer?
Respondido : 06/02/2019 4:00 am
Nikolai
(@nikolai)
Not in the current version.
https://shop.prusa3d.com/forum/software-archive--f87/ironing-options-in-slicer-prusa-edition--t6477.html
https://www.reddit.com/r/prusa3d/comments/9r7rcz/curas_surface_ironing_feature_in_slic3r_pe/
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Respondido : 06/02/2019 4:08 am
supermerill
(@supermerill)
my pull request: https://github.com/prusa3d/Slic3r/pull/821
if you want to test it, you can use my fork: https://github.com/supermerill/Slic3r/releases
https://github.com/supermerill/Slic3r/wiki/ironing
Don't forget to report back. It's useful to see if it's worth merging into the main slic3rPE branch.
Respondido : 06/02/2019 12:48 pm
CapnBry
(@capnbry)
Something I do in Slic3r is to just set the Print Settings -> Advanced -> top solid infill width to 75% of my nozzle width (0.6mm nozzle = 0.45mm width) and up the top solid infill speed to 120% to compensate for the extra print time. Comes out much smoother and nicer looking and doesn't require and additional code. Make sure you're using real E3D nozzles (or at least one that gets the dimensions correct) because knockoffs don't have as much flat around the nozzle orifice to properly "iron" the extrusion.
Respondido : 06/02/2019 5:52 pm
3DALHEMIJA
(@3dalhemija)
Thank you all guys ! CapnBry, I will keep this in my mind.
PS i hope Slic3r PE developers will add this feature soon.
Respondido : 07/02/2019 1:10 am
zuber.b
(@zuber-b)
Hi CapnBry,
Just tried those settings. Much nicer finish...
Thanks,
Zuber
Respondido : 04/03/2019 12:47 am
