Need Replacement Parts
Back a year ago when assembling the I noticed that the MK3S extruder body was a little loose (noted in this link). I have no idea if this caused my current issue but I noticed lately that my hot end always had plastic (using term plastic as generic term) on it and thought nothing more of it. My prints are getting gummed up from what I thought was excess extruding of filament but turns out that over time my Extruder-body rotated slightly enough for the hot end to touch the Fan-shroud slowly meting it and causing the excess plastic I was seeing.
So my question is where can I get a new parts for the extruder and a fan-shroud?
Publié : 06/07/2020 11:04 pm
RE: Need Replacement Parts
You can download replacement parts from here
Drinking alcohol can cause memory loss. Or worse, memory loss!
Publié : 07/07/2020 4:57 am
