MK3S+MMU2S Extruder calibration and Steps
Good day everybody,
I'm new to 3D printers and bought a Prusa i3 MK3S + MMU2S. The device is running good, but I would like to adjust it a bit better and calibrate. Unfortunately, I find no descriptions or HowTo's to the device.
I was able to adjust and calibrate the bed properly, but I would like to correct the extruder, if necessary the steps. Does anyone have tips on how to do this? How do I do it all because even if the mmu2s is installed? Or do I have to disable the MMU2S for it? Are there any more things you should definitely improve or adjust? Maybe something on the hardware? And last question, is there a command to be able to shut down or switch off the printer at the end of a print?
Best regards
Postato : 20/06/2019 9:26 am
