MK3S with Revo - Thermal model calibration keeps failing?
Onno
 Onno
(@onno)
I have a MK3S with a 40W Revo which I recently upgraded to FW 3.14.0 (MK3S_MK3S+-E3DREVO_FW_3.14.0_MULTILANG, in case you want to know the exact version). Unfortunately I get frequent Z-calibration errors whole probing, even after a couple of calibration runs, so I decided to do a full refresh. Unfortunately the thermal modeling keeps failing. AFAIK FW 3.14.0 should allow for the calibration of the thermal model. What can I do to get the working with the (proper) Thermal Model enabled?
Publié : 01/08/2024 3:40 pm
Eef
 Eef
(@eef)
RE: MK3S with Revo - Thermal model calibration keeps failing?
Please read this: https://github.com/prusa3d/Prusa-Firmware/issues/4451
And apply reset_revo.gcode
regards, Eef
Publié : 01/08/2024 9:12 pm
1 personnes ont aimé
Onno
 Onno
(@onno)
I'll give this a shot. Thanks for pointing me to this info! 😀 👍
Publié : 01/08/2024 10:18 pm
Onno
 Onno
(@onno)
I decided to just give it a try without the calibration, and it seems to work okay. I have a 3.5 kit on hand, so I think I'll just print the parts for that and then try my luck with the 3.5 Revo firmware.
Publié : 04/08/2024 8:08 pm
Albert
(@albert-4)
Membre
Thank you for posting this fix @eef. I was having all the  Thermal errors after installing the Revo upgrade.  This little tidbit helped and so far it solved the  issue!
Publié : 07/01/2025 8:49 pm
DenisCasper
(@deniscasper)
Membre
I have installed the revohf(60w version) on the printer . Done the reset.gcode
Made sure I've got the right version of firmware for it . I believe it's 3.13 the latest . Still having thermal anomaly messages and beeps on the printer and it's annoying.  Anything else I could try ? Thanks
Publié : 08/01/2025 3:10 pm
