MK3S+ Sound
512MB
(@512mb)
MK3S+ Sound
IMG_3858IMG_3852IMG_3857IMG_3858
Prusa support is saying that their is no off putting sound but I have 3 MK3S+ and this one is the only one that sounds like this, they were pre-built from factory. 2 weeks old.
also I have another question, when printing calibration cubes I get a filament chunk in one corner, I have tried going down to 0.9 extrusion multiplier, turn off whipe but still getting that effect!
thanks!
Best Answer by Chicago Keri:
To me it sounds like some of the noise is on the Y axis which is pretty common. Try gently pushing the fingerprint areas on the heatbed while the noise is happening, sometimes this drastically changes the noise.
  A filament chunk in a corner? that sounds odd. Does it do it on all layers in the same corner?
I would look over the belts to see if they run centered on the pulleys and that also all of the setscrews that hold pulley to motor shaft are tight.
Napsal : 19/02/2022 9:23 am
512MB
(@512mb)
RE: MK3S+ Sound
IMG_3858
512MB
(@512mb)
RE: MK3S+ Sound
IMG_3857
Napsal : 19/02/2022 9:24 am
512MB
(@512mb)
RE: MK3S+ Sound
IMG_3852
Chicago Keri
(@chicago-keri)
RE: MK3S+ Sound
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говорю по-русски но не очень хорошо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Napsal : 19/02/2022 8:17 pm
