MK3S Severe Constant Under-Extrusion
Jam2020
(@jam2020)
I've tried different temps, different retraction settings, different extrusion speeds, and nothing has helped. When I pull the filament out after it starts to under-extrude I have noticed it becomes larger, diameter wise, then the rest of the filament itself.
Don't know if that's a symptom of anything, but at this point I'm willing to try anything else...
https://imgur.com/a/OxxpNcf
Veröffentlicht : 19/02/2021 11:57 pm
Jam2020
(@jam2020)
RE: MK3S Severe Constant Under-Extrusion
This time the temp was at 219C with retraction set to 20mm/s instead of the 35(?) or whatever the default was.
Veröffentlicht : 19/02/2021 11:59 pm
