MK3S+ sees all gcode models on card except for one model
I have exhausted all my ideas what this issue is. Using Prusa Slicer 2.9.2. MK3S+ has latest firmware 3.14.1-8237. I have never had an issue where I can slice one model where the MK3S+ detects it on the SD card just fine and then slice another model, roughly of the same size and the MK3S+ will not detect that file for nothing. These models are not complex at all. My wife wanted some buttons to use with her sewing craft. One is 0.875"⌀ and the other is roughly the same except it is shaped like an animal head with ears. The animal button is the one that the printer will not detect on the SD card. I did get a pop-up after slicing the animal button that said "looks like a logo or a sign" and I just ignored it. Later I found the option in preferences to disable automatic color change but that made no difference. No errors with either slice.
So to clarify a bit, if I slice and export the normal round button to the SD card, the MK3S+ sees it just fine and I can print. If I slice and export the animal button to the same SD card, the MK3S+ does not detect that gcode file. Any suggestions?
