[Rozwiązany] Mk3S restarts when heating up after removing mmu2s
ColinD14
(@colind14)
Before I removed the MMU2S system the printer we able to heat up with no issue. After I removed the MMU2S from my printer it now restarts when ever I tell it to warm up.
I did move the front screen cables and had them run down the left side by the ports for the stepper motors and I was worried I damaged the board, but there doesn't seem to be damage on the board.
Any thoughts on what is now causing this?
Opublikowany : 24/09/2023 9:16 pm
ColinD14
(@colind14)
RE: Mk3S restarts when heating up after removing mmu2s
It was a short where the wires went into the heater cartage that caused the short. I moved the wires a bit so they weren't in as much stress, and the printer is working fine now.
Opublikowany : 24/09/2023 11:03 pm
