mk3s resets at 72% of print
davidcmorrison
(@davidcmorrison)
I am trying to print the Prusa MMU enclosure 6 file (prusa_mmu_enclosure_6_02mm_pet_mk3s_21h2m.gcode) downloaded from the prusa files site and every time I hit 72% the printer resets and aborts printing the file. I have tried it both from USB (Octoprint) and directly from SDCARD with the same result.  Is there a log file that I can pull from the printer to see why it's resetting? I have checked the md5 checksum of the printed file and it matches that of what was downloaded off of the files section of your website. I am running firmware version 3.8.1-2869 on my mk3s.  Please note, I am using the provided gcode off of the Prusa site with PETG and did not slice this file myself.
Thanks,
Dave
Posted : 28/01/2020 3:42 pm
JBinFL
(@jbinfl)
RE: mk3s resets at 72% of print
Dave:
Not sure if this will be helpful, but you are using the files from Ondrej Stritesky version (The Prusa Official one) and not one of the other remixed files, correct?  It appears there are multiple versions out there and who knows what other people adjusted....
I did not use the Gcode for that file, I used the STLs and split it into two smaller prints back when I did it, but I did remember in the comments that there were some issues like what you were saying in the comments for some of the Gcodes.   That is a downside of those big multipart Gcodes, you lose everything if one item screws up and why I split up the bigger STLs in case there was an issue in the print
Http://gcode.ws   is a website that will let you see the detail of the Gcode lines to see if there is something off in it...
You could use the STL for that one and reslice in Prusa Slicer after saving and importing the Config for the print, filament, and printer settings from the Gcodes to Prusa Slicer to see if that helps.
Strange women, laying in ponds, distributing swords, is hardly a basis for a system of governance!
Posted : 29/01/2020 2:19 am
davidcmorrison
(@davidcmorrison)
Hi jbinfl,
Thank you for the reply, I am using the original Prusa design and the GCODE provided for the PETG version.  I am more than happy to re-slice it but am having an issue finding the STL files, any chance that you know where the STL files for the project are located?  I can pull them from the .mf files but it's a lot easier to just re-slice with the raw STL files.
thanks again!
Dave
Posted : 29/01/2020 3:01 pm
JBinFL
(@jbinfl)
Dave:
Apologies, I mistyped. the .3mf files are what i used to split up the print not STLs.
On my WIN 10 computer, STLs and 3MFs are both listed as 3D object file types and it is not until I look at the properties did I see it was a .3MF and not STLs....
With the new prusa slicer, it should not be that difficult to import the whole 3.mf and delete individual parts
Posted : 30/01/2020 12:06 am
davidcmorrison
(@davidcmorrison)
thanks for all the help!  i was able to reslice the file into the individual parts and they printed perfectly.
dave
Posted : 30/01/2020 6:00 pm
