MK3S print head wiring diagram
Where can I find a wiring diagram for MK3S print head?
Somebody "blobbed" my printer and I have a stray white wire that I need to re-attach....(see attached image)
Publié : 30/03/2020 11:19 pm
RE: MK3S print head wiring diagram
There's only 1 component per set of wires there. The large are to the Heater Cartridge, the small are to the Thermistor. You can see the other white wire still attached to your thermistor in the pic.
I'm not sure you'll have much luck repairing that: https://shop.prusa3d.com/en/spare-parts/205-hotend-thermistor-e3d.html
Others may respond with alternative places to purchase, but I'm not sure.
Ce message a été modifié il y a 6 years 2 fois par nilok
Is your printer grinding? Bearings squeaking? Motors smoking?
Step 1) Wash your Steel Sheet
Step 2) Return to Step 1
Publié : 30/03/2020 11:36 pm
1 personnes ont aimé
