Mk3S+ Nozzle Cleaning?
My problem is the outside of the nozzle, not the inside. I stated a print of 6 or so parts and during the first layer the filament came unstuck and unfortunately I wasn't watching as I should have been. It was PLA and a whole bunch of it caked around the nozzle. Will it pop off when it's dry and hard? If not how do I go about cleaning this up. I usually print only one two parts at a time but I got cocky.
Heat the nozzle THEN TURN OFF and it should clean off while hot - use pliers, tweezers and maybe a wire brush but be careful not to break any of the wires that are attached in the area.
RE: Mk3S+ Nozzle Cleaning?
Yes, like @Diem says: Best to clean the nozzle when the nozzle is hot. Use fine-tipped tweezers and carefully remove most of the PLA. Then use a small wire brush to get the remnants off and avoid the thermistor and heating element cables when doing so. It helps if you move the z-axis so that you have a good amount of room to work underneath the extruded head. I also recommend to put a protective cloth underneath so you won’t damage the table or the metal print sheet.
Usually comes off easily when hot as diem and thomas-14 explained. I had one MegaBlob(tm) with wood filament though where I ended up having to take the hotend out of the extruder assembly to clean it outside.
Usually, though when I was removing a blob on my Ender 3 I broke a wire to the thermister which required replacing the hot end. Fortunately the hot end on an Ender 3 is $17.
Cheers
-Bob
Oh yes, another rite of passage for all of us!
Thanks everyone.
It seems to be working fine now, though it's not looking pristine. Grabbing the PLA with pliers or tweezers didn't seem to work. Most successful was a paper towel folded enough times. I suspect a kitchen scrubbing pad would be good.
Thanks again
I use bits of corrugated cardboard from old boxes while the nozzle is hot. Just cut out a bunch of strips about an inch wide and keep them near the printer. Use the edge of the strips. Doesn't damage the coating on my nozzle X like a wire brush would. Works equally well on a standard brass nozzle though.
