Mk3s not turning on
A1XT
 A1XT
(@a1xt)
Mk3s not turning on
  1. My MK3s a blob then when I tried to remove it I forgot to turn it off then it create a spark. So I bought a full set of hotend kit from Amazon. I assembled it replaced everything but it's not turning on now. The power supply light is on and I checked it there is a 24v coming out from it and going to the board, the fuses seems intact. When I move the bed around it does not even give a glimpse on the lcd. Is my board fried?
Best Answer by Hello:
Posted by: @a1xt
Posted by: @hello
Sounds like it's the fuse as normally it only fries the heater port so I'd replace fuses first
I checked the fuse with multimeter, everything is beeping.
Ok then it seems like it's a faulty controller chip or other component which is pretty hard to replace
Napsal : 27/09/2023 1:36 am
Hello
(@hello)
RE: Mk3s not turning on
Napsal : 27/09/2023 7:17 am
A1XT
 A1XT
(@a1xt)
Posted by: @hello
Napsal : 27/09/2023 2:34 pm
Hello
(@hello)
Posted by: @a1xt
Posted by: @hello
Napsal : 27/09/2023 10:39 pm
Do the fans run for a moment at switch-on?
Napsal : 28/09/2023 12:15 am
A1XT
 A1XT
(@a1xt)
Posted by: @diem
Nope. Nothing it just the green light on the psu
Napsal : 28/09/2023 12:22 am
A1XT
 A1XT
(@a1xt)
Posted by: @hello
Posted by: @a1xt
Posted by: @hello
Darn. I guess I have to buy a new board
Hello
(@hello)
Posted by: @a1xt
Posted by: @hello
Posted by: @a1xt
Posted by: @hello
What you can do is remove every wire that's not to the psu the turn on psu any lights turn on the board
Napsal : 28/09/2023 9:12 am
You probably do have a brick...   It would be worth talking to Prusa Support via chat just to confirm.
Napsal : 28/09/2023 2:56 pm
