MK3S not recovering from crash
maxlobo6293
(@maxlobo6293)
I was printing a fairly tall object with my new MK3S (bought assembled) when it started acting up and the LCD said it crashed and asked to continue. When I said yes it started trying to print a few inches behind where it had been. Now when I try to print it tries to do the auto leveling but fails and gets into some kind of endless non-printing loop.
I've tried (standard) resetting and cycling power and unplugging and plugging it back in, to no avail. What is needed here, please?
Publié : 17/12/2019 6:42 am
Dave Avery
(@dave-avery)
RE: MK3S not recovering from crash
it sounds like one of the x/y axis is binding so the printer can't find the end stop - with the power off make sure both x and y axis move freely from end to end. likely problems are filament garbage caught in one of the belts/pulleys or bad linear bearings
Publié : 17/12/2019 4:44 pm
maxlobo6293
(@maxlobo6293)
Posted by: @maxlobo6293
I was printing a fairly tall object with my new MK3S projects in thane (bought assembled) when it started acting up and the LCD said it crashed and asked to continue. When I said yes it started trying to print a few inches behind where it had been. Now when I try to print it tries to do the auto leveling but fails and gets into some kind of endless non-printing loop. real estate developers in mumbai
I've tried (standard) resetting and cycling power and unplugging and plugging it back in, to no avail. What is needed here, please? real estate development consulting firms
thank you
Publié : 18/12/2019 5:34 am
