MK3S MMU2S won't load filament anymore
Dutchy
(@dutchy)
HI,
I have used my MK3S with MMU2S  a lot and now it starts to give me a headache, I start a print by loading filament in port 1, Nice dry Prusa black PETG. The pre heat the nozzle and bed and start the print. Settings default Prusa PETG in PrusaSlicer.
The filament goes to the nozzle and I can feel and see the filament comes in between the gears and the sensor is triggered on and off (Support Sensor IR 0>1>0>1) and filament flows out the nozzle. like the filament diameter isn't right.
Then it draws back the filament and loads it again, Repeats this a few times and there is building up quite a blob under the nozzle.
It looks like the sensor isn't triggered the whole time I checked it a few times and it does trigger like it should and the its back to 0 again.
Any help please?
MK3s with MMU2S
Prusa Black PETG
230C/240C 85C/90C
No mods
Best Answer by Dutchy:
After looking everywhere and trying everything,... ( 😊 )
I had a look at the help section and the solution was there already,.
https://help.prusa3d.com/article/wprwemqsmj-ir-filament-sensor-calibration
Respondido : 28/12/2019 2:22 pm
Dutchy
(@dutchy)
RE: MK3S MMU2S won't load filament anymore
Respondido : 28/12/2019 2:34 pm
