MK3s made unreliable by FW 3.14 !?
Oli
 Oli
(@oli-4)
Hi everyone,
I hope someone could help me getting my Prusa i3 Mk3s to print properly again, Firmware 3.14. changed it into an Ender V3! Waaaaaah!
Here is the sad story: (scroll down for TLDR!)
After having printed around 1000 cases with our prusa mk3s at work, I bought a used one for myself (last August), since I was fed up with my unreliable EnderV3se.
I carried my new printer home and printed a absolutely wonderful flawless cam holder.
I LOVED IT SO MUCH! FINALLY A RELIABLE 3D-PRINTER!
Then, destiny struck:
I UPDATED TO FIRMWARE 3.14 (this was back in October/November) since then my Prusa seems to channel my old Ender somehow:
Unreliable Prints, and ever changing Z-Axis settings, one day its great, next day no adhesion with the same settings the same file. Whyyyyy? :../
MY LOVE STARTED TO FADE AWAY....... =:-|
I moved the Pinda sensor after the XYZ Calibration caught the paper. (space: one cable tie)
I did SEVERAL XYZ Calibrations with SEVERAL different Firmware Versions and SEVERAL full resets to no avail.
I have even changed the whole Print head (one was provided by the former owner) to no avail.
MY LOVE STARTED TO TURN INTO RESENTMENT.... ):-(
Sometimes it sticks, sometimes not, depending on the mood of the day, worse than my EX. (Yes, I know, really!)
Z-Offset calibration is more than irksome, since it looks scratched (too low) when it sticks, but does not stick properly if it is at the right hight.
I have cleaned the sheet with Alcohol and Soap to no change.
I installed 3.14.1. and the paper gets caught again!
NOW I COMPLETELY LOST MY WILL TO LIVE.....
What am i doing wrong here?
I don't get it why mine is not printing anything properly but the one at work is sh*tting out cases with "fire and forget", it just works...
I spent months on this, and now looking at any prusa just makes me mad/sad..... (Which is some kind of brand recognition, I guess 😉
I hope there is some advice out there..... the last hope......
TLDR:
Working Printer "disabled" by Firmware Upgrade 3.14
Several Full Resets Done
Several XYZ Calibration done
Paper caught.
Moved Pinda
Changed Printhead
Updated, Downgraded and Updated FW (now 3.14.1)
Paper gets caught again in XYZ,
Cleaned with Alcohol and Soap.
Still no proper adhesion or very sad/bad first layer
Could'nt even install my new MMU, because for what?
I am tired now.
Please help!
Thanks for your time.
Oli
Publié : 30/01/2026 2:20 pm
TomyCool
(@tomycool)
Membre
RE: MK3s made unreliable by FW 3.14 !?
Hi Oli,
Have you performed the PID calibration? You'll find it in the calibration menu.
Just a little more perseverance, you're almost there.
Publié : 30/01/2026 4:36 pm
Meekrob
(@meekrob)
Use 0000 steel wool on your PEI sheet to get things to stick. After that, work on the next problem.
Publié : 06/02/2026 12:09 am
Oli
 Oli
(@oli-4)
I will keep that in mind.
But why would the surface AFTER the firmware update suddenly be bad? It was sticking nicely before 3.14....
Publié : 07/02/2026 7:03 am
Oli
 Oli
(@oli-4)
Hi TomyCool, thanks for the tip. Unfortunately no dice, still bad, still sad..... :/
Publié : 07/02/2026 7:04 am
Oli
 Oli
(@oli-4)
Ok, I reset the printer, installed 3.14.1 again, and readjusted the Pinda sensor again. Did the XYZ sh*t for the 20th time.
I still have the same problem, one day it is great, printer off, next day it will not stick at all and the Z-Axis need reajustment AGAIN.
This is stupid, should I go back to chinese brands?
Anyone any idea? Otherwise I will gladly bin it, it causes me too much sadness, actually, I am pissed off at this time....
Publié : 19/02/2026 10:01 am
TomyCool
(@tomycool)
Membre
Hi Oli,
If we disregard a mechanical problem, it might be a temperature issue.
https://help.prusa3d.com/article/thermal-model-calibration_382488
Or perhaps a problem with the heated bed leveling. You could consider the "Nylock Mod".
Hope this helps.
Publié : 20/02/2026 11:45 am
Meekrob
(@meekrob)
I'd second looking into a temperature issue. Prusa claims the SPINDA is temp independant, but that's certainly not my experience. Also get pronterface or some way to send commands to your printer and see the values for your mesh leveling.
Publié : 23/02/2026 6:44 am
