MK3S kit IR Sensor always reading 1 - even with removed from extruder housing.
https://imgur.com/a/WRdmm4u pics because I wouldn't believe it's not a wiring issue either. To be clear I can have the sensor unscrewed and looking at the empty U sensor and see a value of 1, then block the sensor and see a value of 0.
I keep finding this issue in old posts but nothing with a solid solution.
As a side note I can change the sensor state when it's detached but the flag (moves freely, magnets set correctly) won't trigger a state change either. That's 2nd on the list to fix. I printed 1 0.5mm spacer but didn't help, after I finish some more prints without the sensor I'll try other/more packers.
I'm going to keep looking on my own, but if anyone has a tip I'd appreciate it.
Opublikowany : 11/10/2020 3:31 pm
