Mk3s+ hotend mantainance/extruder disassembly?
Talinseven
(@talinseven)
I am in the process of upgrading my mk3s extruder to the mk3s+. I have discovered that my hotend is a mess from badly (not) torqued nozzle. I want to continue the assembly, but go back when I'm done to try to salvage the hotend (it printed fine before disassembly).
Is there a guide to getting the hotend that isn't just full extruder disassembly? It seems like Prusa changed the design to allow this, but I'm failing to find a particular article/guide.
Napsal : 18/09/2021 11:15 pm
E3D guide is good
The E3D hotend assembly guide is very good. Pay careful to the bit about screwing in the nozzle flush, backing it out to the desired < 1mm gap, THEN hand-tightening the heatbreak up against the nozzle. The important bit is that, when properly tightened, it should be impossible to tighten the nozzle flush up against the block.
Napsal : 19/09/2021 3:13 am
1 lidem se líbí
illustration
As Bobstro said, be careful.  This diagram illustrates on problem in edition to not getting nozzle against the heatbreak.
Posted by: @miriam
Napsal : 19/09/2021 11:14 am
