MK3S firmware update 3.10.1 --> 3.14.1 caused many problems
[Gelöst] MK3S firmware update 3.10.1 --> 3.14.1 caused many problems
PSVC
 PSVC
(@psvc)
Mitglied
Today I decided to update the firmware as it was dragging down already several versions. The printer was working perfectly before the update. After the update, the first problem I discovered was that the extruder was running super fast during the filament loading. I had to clean up the mess it caused manually. When I tried a test print, the extruder was overextruding badly. Next I decided to try self test. It keeps failing the X-axis test. Next I downgraded to 3.14.0 and 3.11.0, but the x-axis problem persists. Maybe I'll try to downgrade the software even further, or is there some tips or tricks I should try next? Thanks!
Veröffentlicht : 03/12/2024 6:38 pm
PSVC
 PSVC
(@psvc)
Mitglied
RE: MK3S firmware update 3.10.1 --> 3.14.1 caused many problems
It looks like the full factory reset resolved this issue. Now I'm able to use the latest firmware.
Veröffentlicht : 03/12/2024 8:25 pm
