mk3s fails self test 3.8.0 fw
SteveJ
(@stevej)
hi..upgraded to fw 3.8.0 ...self test fails and gives an error regarding x belt axis...altho there is no problem afaik...go back to 3.7.2 and passes everything in self test fine..is this a known issue? any suggestions? regards steve
Veröffentlicht : 08/09/2019 11:35 pm
Chris
(@chris-16)
RE: mk3s fails self test 3.8.0 fw
how does it fail? is there something specific that fails?
Veröffentlicht : 09/09/2019 4:43 am
SteveJ
(@stevej)
it just fails saying axis length error...i managed to sort it kind of...what i found is if i autohome the run self test it passes fine...its only  when i start off the selftest with extruder say in middle of x it fails..
Veröffentlicht : 09/09/2019 11:24 am
Nailig
(@nailig)
I have the same issue. The printer prints just fine with 3.8.0, but after i changed the einsy case I thought I would do a self test. After the fan test it does not seem to try a x-axis test, the z-axis is raised and then it immediately says failed axis length, axis x
but the printer just prints fine after I skipped the self test and calibrated the axis.
Veröffentlicht : 27/09/2019 1:34 pm
