mk3s extruder and old filament sensor compatibility?
Hi, just a quick question but would anyone know or think the new 3D printed extruder and other printed parts for the mk3s will work with the old filament sensor? Not sure if I wanna get the upgrade yet but easier maintenance to the ptfe tube and better cooling with the airflow sound pretty nice. Thanks!
Re: mk3s extruder and old filament sensor compatibility?
Completely new design. What I can see there is no space for the old sensor.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
My major hope is the FW for the Mk3S extruder is forked to use the 7x7 bed calibration; such a no brainer over the interpolation error.
The two sensors communicate differently with the MCU and use different pins, so I would guess it's an "all or nothing" situation. with regard to upgraded parts and firmware.
As for a 7 x 7 calibration, I have seen the "keep out" document which superimposes the build plate onto the magnet map. If they are going to do this, it will be extremely difficult at best.
Peter
Peter
I cry boo...maybe we can rewire the old sensor while waiting 😀
I bet the new sensor is like 4 wires. maybe they got it down to 3
The old sensor was 4 wire, the new is only 3. Both connect to the Einsy in the same 5-pin socket, with the old spare pin being used for the new sensor, leaving the two old sensor comms pins spare.
Peter
