MK3S died..
paul19
(@paul19)
MK3S died..
..in the middle of a print my MK3S suddenly went power off: display dark, no function of the on/off switch anymore. The power supply is providing 24V and the 3 fuses on the RAMBo are ok.
Does anybody have an idea what to do?
Many thanks
Opublikowany : 18/04/2022 8:19 am
RandyM9
(@randym9)
RE: MK3S died..
Posted by: @paul19
..no function of the on/off switch anymore. The power supply is providing 24V...
This is a bit confusing. If the power switch no longer functions, how and where are you reading 24 volts?
Opublikowany : 19/04/2022 4:42 am
paul19
(@paul19)
RE: MK3S died..
Sorry for the misleading description: The switch works, but printer remains dead. The voltage was measured with a voltmeter at the output of the power supply.
Opublikowany : 19/04/2022 7:09 am
RE: MK3S died..
Check the fuses on the Einsy side of things.
Opublikowany : 19/04/2022 8:46 am
paul19
(@paul19)
RE: MK3S died..
Thanks for all suggestions. A live chat with Prusa (very competent and supportive!) ended in sending the printer for repair. Will post the result as soon as I have it back
Opublikowany : 19/04/2022 10:25 am
