MK3S, Dial stopped working and also says "no SD card"
So I replaced my hot end this morning. All went fine, and so did the calibration wizard afterward. But when I opened up the menu after to make first layer calibration, the dial has stopped working. The clicker still works, not nothing happens when i rotate it. So basically, I can't do anything else. I also noticed that the menu says "No SD card", when I know its definitely in.
Any idea, what is wrong?
Publié : 28/06/2019 2:22 pm
RE: MK3S, Dial stopped working and also says "no SD card"
Sounds like you need to check the 2 ribbon cable connections between the control panel and Einsy control board. One is probably ok as your lcd is working but the other will be doing the sd card and encoder info.
Publié : 29/06/2019 12:57 am
