MK3 to mk3s upgrade - gcode fails?
Alpha
(@alpha)
Odd one - just upgraded my MK3 to a mk3s and everything working fine, done a few prints etc.
However, I've noticed the calibration square gcode that was on the as card from my MK3 that I used for z-axis alignment fails at exactly the same spot every time with a 'min bed fixed error'...
It's no Biggie as I can realise, but is there a difference between mk3s and MK3 gcodes? I thought they were pretty generic??
Just interested to understand
Posted : 17/08/2019 6:35 am
RE: MK3 to mk3s upgrade - gcode fails?
In my experience, the gcodes are interchangable ... the printer doesn't care.
But Z-Axis alignment is an automatic firmware function that simply bangs the axis to the top stops.  You don't print anything to do that.
Posted : 17/08/2019 7:23 pm
