MK3 to MK3S+ kit assembly & firmware question
Hello all,
I have had a Prusa MK3 (self built) for a few years and finally decided to reprint all new parts for it and install an upgrade kit (MK3S+ upgrade kit) I purchased a year ago. I have everything assembled and ready to go but ran into an issue with the firmware upgrade. I flashed the MK3S+ firmware, which I now believe is the incorrect firmware to flash for a upgraded MK3??? But reading through the docs I am a little confused by what firmware I should be flashing to the motherboard. On top of that, my newly install IR sensor is not registering / working, and also the reason why I am concerned I have the incorrect firmware install. Could anyone please confirm which firmware I should in using. Thanks!
Respondido : 26/12/2023 2:20 am
