Mk3 slicer not installed
I downloaded the prusa firmwire and driver , while installing it shown all model files are missing .after installation try to run slicer pe but it shows error files are not found.
What should do ??
Opublikowany : 15/07/2018 12:48 pm
Re: Mk3 slicer not installed
Hi Vinaykr
when you loaded the drivers you should have been presented with a screen showing all of the available printers, so you could select the ones you want.
if you are in Slic3r main screen, there is a configuration drop down menu, if you click on that and choose configuration wizard, you should be offered the choices again
Opublikowany : 15/07/2018 3:26 pm
