MK3+ rebooting
I have a 2 month old MK3+ that when trying to connect to Octoprint the printer reboots and I can not connect. Just started 1 day ago.
I bought it pre-assembled and it had been working fine. so I'm at a lost. Maybe the board has gone bad. What do you think?
Probably a loose connection, unplug and reinsert all the plugs on the electronics boards. Are you connecting by usb? If the problem persisits try a different cable.
RE: MK3+ rebooting
Its printing from the SD card right now. I will try both of those tomorrow. see what Happens
RE: MK3+ rebooting
I figured it out finally I had RPi raspberry pi switched on in the settings. Turned it off and problem was gone. I was trying to adjust the Z setting and must have clicked when I should have clacked. Thanks for the help
