Mk3 filament sensor seems to have died.
Machi
(@machi)
Hello, my filament sensor used to work perfectly for the past months, today it did not stop a print after running out of material and now, when I try to activate/deactivate, I see a sign that says n/a and after clicking it's says check wiring and etc. Tested the cable, it's okey, the votage in the vcc is okey also. Is this common? Should I open a support ticket?
Thanks!
Napsal : 29/04/2020 11:50 pm
Machi
(@machi)
RE: Mk3 filament sensor seems to have died.
So nobody can help me?
Napsal : 03/05/2020 3:31 pm
