MK3 Extruder disassembly - removing bontech from idler
FunPlastic
(@funplastic)
I want to try out Petehagoras extruder design that I found on this thread
https://shop.prusa3d.com/forum/how-do-i-print-this-printing-help--f63/any-ideas-how-to-get-this-flexable-material-to-pri-t14765.html
But I can't find a disassembly guide for the MK3. It looks like I should be able to follow the general steps for the MK2 though.
But how do I go about removing the bondtech gears from the idler? If I remember correctly, pushing the axle into the idle took a bit of force when I put the kit together.
Opublikowany : 28/08/2018 4:33 am
