Mk3 displays message to upgrade firmware
Ben
 Ben
(@ben-4)
Is there any way to cancel this message? It comes up before every build, and doesnt proceed with build until you acknowledge it.. No big deal, but on a couple of occasions I forgot to acknowledge it, and came back to the printer still sitting there waiting, instead of my part finishing up.
My printer seems to be running great and I am hesitant to change the firmware when that is the case, unless some great new solid improvement has been implemented.
Thank!
Opublikowany : 24/02/2019 4:16 pm
vintagepc
(@vintagepc)
Re: Mk3 displays message to upgrade firmware
I'm betting if you remove the M115 U3.4.1 ; tell printer latest fw version line from the printer custom G-code it'll stop.
But FWIW the 3.5.2 firmware does have some good improvements:
- No more power supply clicking when heat bed PWMs
- No more print fan whine when running at less than 100%
-and a few more QOL improvements.
Opublikowany : 24/02/2019 4:27 pm
Ben
 Ben
(@ben-4)
Thanks for the quick reply! I never think to look at the G-code!
Opublikowany : 24/02/2019 4:41 pm
