MK3 Display Issue
The display on my MK3 inconsistently show garbage text on the end of the status/message line (bottom line on the display). For instance, as shown in the images below (and attached), I am thrinting the file "BennyB.gcode" but you can see there is additional, and seemingly random, text following the file name. (In the first example, there is an extra "%1R" on the right; on the second there is the hotbed symbol and "SD" on the end.) The extra text is always copied from somewhere on the display, and it is only there part of the time. Thrinter functionality is not affected as far as I can tell.
Has anyone else seen this? Should I be worried?
Re: MK3 Display Issue
Last time I had trash on the display I did a full factory reset, with required "start from scratch" calibration. But I had trash everywhere.
If the problem exists only on the last line, you may want to verify the SD card is formatted correctly as FAT32 and not using a format that allows unicode characters.
