MK3 Always printing line infill?
tim.e7
(@tim-e7)
Hello,
I'm not sure how this is possible, but I'm slicing parts with grid infill at 10% in slic3r prusa edition 1.4.1. For example, I've tried printing a simple test box with 2 walls, 10% grid infill and exported the Gcode. looking at it in the preview within slic3r it shows a uniform grid pattern as I would expect. I also loaded the Gcode into another software and again it shows a nice, uniform grid pattern. Then i take that Gcode and load it into the my Prusa Mk3 running 3.3.1-845 firmware and I get line infill out. I'm not even sure how this possible. My theory is that its mixing up travel movements and extrusion movements between points, as it looks like the lines are connected at the same points that a grid pattern would be.
Has anyone seen this before?
Thanks,
-Michael
Postato : 24/10/2018 5:25 pm
Martin Stoufer
(@martin-stoufer)
Re: MK3 Always printing line infill?
How far apart are the two walls? It may be that an infill is attempted, but there isn't enough physical space to actually extrude the infill.
Postato : 24/10/2018 9:16 pm
