Mk2 or MK3 fan
Angelscry
(@angelscry)
Mk2 or MK3 fan
Hi everybody.
I have actually a MK3S that I have successively upgraded from MK2 to MK3S MMU2S model. The print fan make a lot of noise since several weeks now. It still spinning, but I think that some filament dust still stuck inside. I have try to do my best to clean it, but it still make noise. Also If I try to use the calibration wizard, the print fan fail the test.
I'm actually planning to replace this print fan by another one, but if I go Prusa shop there is 2 version for this print fan :
- MK3 Print Fan (5V) which is not compatible with MK2S
- MK2/S Print Fan (12V) which is not compatible with MK3.
As my printer is an MK2 upgraded to MK3S, and as the print fan actually installed on it is the MK2/S version, which version of the Print Fan I need to order?
Thank you in advance for your help.
Veröffentlicht : 30/03/2019 1:15 am
Re: Mk2 or MK3 fan
Look for 5V or 12v mark on the fan label; that's the best way to check.
Veröffentlicht : 30/03/2019 1:40 pm
gwenael.c
(@gwenael-c)
Re: Mk2 or MK3 fan
That's the 5V one. I totally forgot to check if it may be indicated on the fan label.
Thank you very much.
Veröffentlicht : 31/03/2019 4:25 pm
