Missing lines during print
digitalis49
(@digitalis49)
I have an MK3S.
I have printed the MK3S Extruder
I am using Prusa's dual extruder drive gears
I am using Prusa's stepper motors.
The problem seems to be a regular miss of lines during print - all layers.
I have tried 3 sets of Drive gears, replaced Extruder motor, printed several Extruder bodies, checked and re-checked E-steps - all to no avail.
I have been grappling with this issue for several weeks now.
QUESTION: Can you please look at the attached image and offer some advice.
Thank you.
Veröffentlicht : 07/10/2021 11:28 pm
Mitglied
First layer
You are having a first layer adhesion issue - try cleaning the bed and adjusting you Z offset by about -0.050
Veröffentlicht : 08/10/2021 10:01 am
digitalis49
(@digitalis49)
Thank you Chuck but I have adjusted the Z Offset + & - to no avail.
Although the photo shows a 1st layer print - the same issue prevails on all layers.
Veröffentlicht : 08/10/2021 11:25 am
Mitglied
Can you do a first layer test and post the image of the rectangle on the next and held up to a light.  This could be an extrusion issue.  The photos will help.
Posted by: @digitalis49
Veröffentlicht : 08/10/2021 11:31 am
