MINTEMP error perisists with multiple thermistors tested
[Solved] MINTEMP error perisists with multiple thermistors tested
Shipe Design
(@shipe-design)
As the title states, I'm getting MINTEMP on power up. I have tried multiple new thermistors, all of which check out on a multimeter. Also persists when swapping the hotbed thermistor in its place.
Is the Einsy borked, or is there something else I'm missing?
Thanks!
Napsal : 28/05/2021 9:13 pm
Shipe Design
(@shipe-design)
RE: MINTEMP error perisists with multiple thermistors tested
Nevermind... found a burned component on the board. Support was very helpful and is sending a replacement under warranty.
Napsal : 28/05/2021 9:41 pm
1 lidem se líbí
