MINTEMP Bed Error only when doing a color change
ksbdude
(@ksbdude)
Every time that I use the color change feature built into prusa slicer I get a MINTEMP Bed Error during the color change. This error only happens when changing filaments during a print. I then have no way to resume the print and must restart resulting in a failure. I used to be able to use the filament swap at a specific layer feature without issue. I am not using an MMU right now. Any help is appreciated.
Veröffentlicht : 06/03/2022 7:26 pm
screw_ball69
(@screw_ball69)
RE: MINTEMP Bed Error only when doing a color change
Are you printing somewhere cold? I know if mine drops below 10 degrees I have to warm it up with my hand before I can do anything since its in a uninsulated shed.
Veröffentlicht : 07/03/2022 10:25 pm
ksbdude
(@ksbdude)
No, I am not printing somewhere cold.
Veröffentlicht : 07/03/2022 11:19 pm
Zoltan
(@zoltan-d-2)
Mitglied Moderator
For programmers to investigate you problem you need to provide the used fw version info. A short video with the display view when failing would be very helpful.
Veröffentlicht : 21/03/2022 6:31 am
