Mintemp Bed error
Xyst 3d
(@xyst-3d)
Mintemp Bed error
I just noticed that I got a "Mintemp BED" error at the exact same location (bottom left of heat-bed) at the start when its printing the skirt... Does anyone have an idea as to what the problem is?
Thank you.
P.S I strongly believe the wiring is okay because as long as I avoid that certain spot on the heat-bed everything prints okay.
Posted : 24/04/2021 3:18 am
Clarmrrsn
(@clarmrrsn)
RE: Mintemp Bed error
Move the bed and head manually to that point and check the bed thermistor/cable with a multimeter.
https://help.prusa3d.com/en/article/mintemp-error-and-mintemp-bed_2169
Chances are its either a loose connection on the einsy board, or a break in the bed thermistor wire that is only an issue at that point.
Speak to Prusa via chat on the EShop, they may send you a new bed thermistor under warranty.
This post was modified 5 years ago by Clarmrrsn
Tank you very much!
Posted : 24/04/2021 9:21 am
Clarmrrsn
(@clarmrrsn)
P.S remember to switch off and move the bed and head slowly so you dont generate a back current.
Either that or start a print on the problem area, when you get mintemp error switch off, unplug the bed therm and test it.
Tank you very much!
Posted : 24/04/2021 9:30 am
