Min temp error Mk3s
gatonini@zoominternet.net
(@gatoninizoominternet-net)
Min temp error Mk3s
Hi if I leave my printer sit over nite turned on when I go to it in the morning it shows min temp error but if I reboot it the error goes away and everything is normal again any ideas ? Thanks Gary
Opublikowany : 07/03/2019 4:52 pm
Frio
 Frio
(@frio)
Re: Min temp error Mk3s
Ambient temp real low? I get the same thing from time to time.
Opublikowany : 07/03/2019 5:18 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
Where I print the air temp was 11 c this morning outside it was -22 C, and once I got the wood fireplace going for a while the room is up to 18c and all is normal for the printer again... I asked Prusa about it and they said 16c or above for the room temp where your printer is unless you have a heated enclosure
Opublikowany : 08/03/2019 7:05 pm
In another thread found using search MINTEMP is triggered below 15c ...
Opublikowany : 08/03/2019 8:10 pm
