mid print, z axis dropping, then resuming
aaron.s22
(@aaron-s22)
I have a file that I designed in a parametric cad program, that is causing me some problems. The stl loaded into prusa control fine, and the gcode preview looked fine, but when I ran the print it failed each time in the same spot. I tried reloading and moving/rotating the part, and still ran into the same problem. I think the z axis begins to crash towards the bed, and then hits the model and stops, and then resumes printing at the lower height. I have attached a picture of some of the failed attempts.
Respondido : 16/04/2018 12:30 am
