Mesh bed leveling doesn't see 3rd point
Erik
 Erik
(@erik-3)
I've started having a problem recently. When the printer does mesh bed leveling, it will sometimes miss the third leveling point and hit the endstop on the right side of the bed. This happens about once every 10 prints. I just reset the printer to clear the error and retry the print. Everything works then. Does anyone know what could be causing this?
Opublikowany : 16/08/2018 4:36 am
Punkgeek
(@punkgeek)
Re: Mesh bed leveling doesn't see 3rd point
What is your live Z offset? Could it be that you are at the edge of pinda sensitivity - i.e if it were about 1.1mm perhaps adjust the pinda down so it is more like 700um.
Opublikowany : 16/08/2018 5:35 am
Erik
 Erik
(@erik-3)
I'll give that a shot. I'm at about -1.2 because of the powder coated sheet. The sticker sheet is around -.7.
Opublikowany : 16/08/2018 2:03 pm
