Mesh Bed Level Settings - Missing
DarcShadow
(@darcshadow)
Under the settings menu, I do not have the Mesh Bed Level option anymore. It was there originally but when I tried to go to it the other day to change to 7x7 I can't find it, I've looked several times and checked in the manual to make sure I'm looking in the right place. It's just gone. Is there a setting someplace that I'm missing that turned off the option of changing the mesh bed level settings? Outside of reloading firmware does anyone have suggestions on how to get the settings option back?
Postato : 21/06/2019 1:06 pm
vintagepc
(@vintagepc)
Utenti
RE: Mesh Bed Level Settings - Missing
A few of these things have shuffled around - I'm not at my printer to check, but has it perhaps moved to the calibration menu?
Postato : 21/06/2019 2:12 pm
DarcShadow
(@darcshadow)
There is a think in the calibration menu, but it just runs the process, doesn't give me any options to change settings.
I know the option to change the settings existed at some, I remember see them when I first setup the printer and was going through the menus but for the life of me can not find it again, and it's certainly not where the manual says it should be.
Postato : 21/06/2019 5:25 pm
What FW version are you using? And printer model, too.
But on my printer it is:
Settings>Mesh Bed Leveling ->
Questo post è stato modificato 7 years fa da --
Postato : 21/06/2019 5:27 pm
1 persone hanno apprezzato
DarcShadow
(@darcshadow)
I'll have to go back and look at the FW version, but it's pretty recent. We just received the printer MK3, a few months ago, missed the free s upgrade by a couple of weeks.
Postato : 21/06/2019 6:26 pm
Dave Avery
(@dave-avery)
you probably need to update to the latest to get the 7x7 mesh bed - easy to do from a copy of PruseSlicer with a USB cable
Postato : 21/06/2019 6:28 pm
DarcShadow
(@darcshadow)
I figured that would fix it, but I shouldn't have to, it was there before and has disappeared some how.
Postato : 21/06/2019 6:34 pm
I'm betting that the firmware didn't reconfigure itself...
Postato : 21/06/2019 7:32 pm
DarcShadow
(@darcshadow)
Updated the firmware and the mesh bed level settings are there. I also checked the version of FW before loading and realized it was an old enough version that the 7x7 option was never there, so I must have simply been mis remembering. Guess I read it in the manual and just though I had seen it on the machine.
Postato : 26/06/2019 1:18 pm
The mesh level settings are under Settings, the mesh level function is under Calibration ...
Postato : 26/06/2019 5:44 pm
