Maximum file size on SD card reader?
keith.g5
(@keith-g5)
Hello all. Is there a Maximum file size limit on SD card reader? Printing on a MK3 with the latest firmware I'm having a problem.
The file that I want to print is about 44mb in size. Written to a 64mb SD card. The card is not recognized by the controller (no SD mounted) I switched the micro card to a different adapter and still nothing. I know the micros and adapters are good. So my work-around was this. I split the cad model into 2 halfs in my cad software. Re-sliced in Slic3r 1.4.3 at the same resolution of ,2mm. Exported that ~22mb file to a 32mb micro SD in an adapter. Card was read right away! Ill have my print in ~8 hours.
So to ask again; Is there a M aximum file size limit on SD card reader? 32mb yes 64mb no?
Thank you.
Napsal : 14/02/2019 11:36 pm
BillC
(@billc)
Re: Maximum file size on SD card reader?
A bit of confusion here on card size (Gb) and file size (Mb).
If you save your 44Mb file to a 32 Gb FAT32 formatted SD, then Prusa can read and print it. What it can't read is any file size at all with the SD card formatted as XFAT or NTFS.
This link may help you use the whole card, but it may be easier and safer to just get and use smaller card(s).
https://answers.microsoft.com/en-us/windows/forum/windows_10-files/format-a-sandisk-extreme-64gb-micro-sd-card-to/ff51be64-75b9-435f-9d39-92299b9d006e
Bill
Tagaytay City, Philippines
Napsal : 15/02/2019 8:57 am
toaf
 toaf
(@toaf)
are you sure your gcode fits on such a small card?
Napsal : 15/02/2019 9:55 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Bill, you just confused me 🙁 I always understood that lower case "b" stood for "bit" and upper case "B" is "Byte" 😉
Peter
Napsal : 15/02/2019 10:35 am
Olef
 Olef
(@olef)
Gb = gigabit. GB = gigabyte. etc.
Napsal : 15/02/2019 12:19 pm
keith.g5
(@keith-g5)
Re: Maximum file size on SD card reader?https://shop.prusa3d.com/forum/download/file.php?id=24194
Hello All. Thanks for the replies. I apologize for how I typed the file size/card size. Mm Bb. I know better. The reply from Bill is spot on. It was the formatting of the card that was the issue. It is formatted as exFAT. I'll change that.
-Keith
Napsal : 15/02/2019 2:13 pm
keith.g5
(@keith-g5)
OK, Looks like this SDXC card cannot be formatted as FAT32 as that option is not available. Ill just put it back in my phone.
When the printer did not read the file I first thought "file size" problem. Thanks Bill, as it is "Format style".
Napsal : 15/02/2019 2:32 pm
richard.l
(@richard-l)
Member Moderator
I've been using this for some time to format SDXC cards to FAT32. Works every time.
http://www.ridgecrop.demon.co.uk/index.htm?guiformat.htm
Napsal : 15/02/2019 4:16 pm
keith.g5
(@keith-g5)
Thanks Richard. I'll give it a shot.
Napsal : 15/02/2019 6:26 pm
Sembazuru
(@sembazuru)
Yeah, Microsoft doesn't think you should be formatting these cards with anything but the default formatting as defined by the SD specification, therefore they don't provide the tools. Technically it does work, so that is why you have to go to 3rd party tools in Windows to do this. See this link from SanDisk about which type of cards have which range of sizes, and what their default formats are: https://kb.sandisk.com/app/answers/detail/a_id/2520/~/sd%2Fsdhc%2Fsdxc-specifications-and-compatibility
(Note, small microcontroller based projects, like the Einsy boards at the heart of our i3 printers, can only read FAT16, and FAT32 (maybe FAT and FAT12, I haven't tried those). I should probably dive into the source at some point to see how it handles the extended filenames of FAT32. I didn't realize that any of the Arduino FAT libraries could...)
See my (limited) designs on:
Napsal : 15/02/2019 6:58 pm
gnat
 gnat
(@gnat)
I thought I read somewhere that 64GB+ cards weren't supported, but I'm not positive on that.
Seems to handle them just fine. I haven't tried unicode characters, but as I'm a pedantic Linux user my gcode names are usually at least 20 characters (e.g. "black lion neck rear_0.4x0.1mm_MK3_PLA.gcode"). The MK3 reads them fine and just scrolls the name on the display when I pause on it in the list.
MMU tips and troubleshooting
Napsal : 15/02/2019 8:30 pm
Sembazuru
(@sembazuru)
Probably because 64GB+ cards (which are SDXC because SDHC maxes out at 32GB) are by default formatted with exFAT. If you are able to reformat them with FAT32 they should work. Please read the SanDisk link I pointed to so you can see the ranges of the different SD card styles, and the default formatting for each style. (FAT32 should be good up to 2TB.)
Yes, my point was the MK3 that I have (presumably also the earlier versions) handle extended filenames fine. The Prusa firmware is compilable by Arduino, like my Arduino UNOs and AdaFruit Feathers. Last time I worked with Arduino data logging to an SD card I was limited to 8+3 filenames by the Arduino FAT library that I was using. I tried looking for a FAT library that could handle the extended filenames and was unable to come up with one. Now that I see an Arduino compatible project handling extended filenames I want to see how they do that for my own future use. (Though, I wonder if there are some extra tricks to use as at least in pronterface if I try to get a listing of the files on the SD card I see the 8x3 filenames... I haven't tried sending the gcode instruction to get the file listing yet, and I can't until I return home to my MK3.
But... me thinks I'm drifting away from the thread.
Napsal : 15/02/2019 9:11 pm
BillC
(@billc)
Peter
Yes Peter, you are right - but it is also convention to capitalize the part of an expression that was wrong (for emphasis) - and it was the Mega/Giga that were confused.
Perhaps I should adopt Thingiverse speak and call everything mb - who needs to convey meaning accurately in this world 😈
Bill
Napsal : 16/02/2019 5:10 am
Atheneum Library
(@atheneum-library)
OMG! Thank you Richard! My PC didn't have a SD card slot so I bought a reader and a new card...I guess my eyes were bigger than my stomach. I thought my reader was causing teh issue! Thank you!
Napsal : 09/04/2019 8:23 pm
