Max temp error, then blank screen, now printer stops while printing.
Page 6 / 6
Hello
(@hello)
RE: Max temp error, then blank screen, now printer stops while printing.
ok turn printer off conect evrything up then do a first layer cal at any point if you here a pop or any strange noise turn printer off asap
Posted : 08/01/2023 4:57 am
Scottyos
(@scottyos)
going to give that a whirl. hang tight.
Posted : 08/01/2023 5:02 am
Hello
(@hello)
let me know when evrything is conected
Hello
(@hello)
fingers crossed
Posted : 08/01/2023 5:04 am
Scottyos
(@scottyos)
So first time I went to turn it on it was stuck on the loading screen, however I just pulled a few things out and put them back I likely didn't have the filament sensor in correctly but it's booting up right now. I just am going to unload the filament that I had sitting in the extruder.
Posted : 08/01/2023 5:09 am
Hello
(@hello)
ok if it got stuck on loading screen turn printer on and of a couple of times and see if it does it again
Posted : 08/01/2023 5:11 am
Scottyos
(@scottyos)
I managed to unload and load filament no problem, I have a short print i'm going to try. I appreciate all the help today. I'm thinking it could have been a lose connection that was causing the machine to disconnect. It's looking like the first layer is going well, no issues that I can see with temp and the screws holding in the wires for the power are all clean contacts and tightened in.
Posted : 08/01/2023 5:12 am
Hello
(@hello)
ok let me know how print goes if it gets stuck on loading screen again or somthing else happens it has to be the psu
Posted : 08/01/2023 5:14 am
Scottyos
(@scottyos)
Well thank you again for all the help I'll give this thread a reply if anything pops up. You're my new favorite internet stranger. But all jokes aside, I really apprecaite you walking me through all this. It's greatly apprecaited. 🙂
Posted : 08/01/2023 5:15 am
Hello
(@hello)
all good happy to help you
Posted : 08/01/2023 5:17 am
Hello
(@hello)
hows it going
Posted : 08/01/2023 5:27 am
Scottyos
(@scottyos)
So far so good. it's made it past the point of shut off from the last print. I can't see anything that's looking off at all. No weird sounds, temps staying even, it actually sounds better than the last good print I had a couple weeks ago.
Posted : 08/01/2023 5:30 am
Hello
(@hello)
thats good that its working know
Posted : 08/01/2023 5:32 am
Hello
(@hello)
Just thought Id check in did the print work
Posted : 08/01/2023 7:46 pm
Scottyos
(@scottyos)
It did! It turned out great. I'm halfway through a second print now and no issues along the way. Just smooth sailing. Thanks again!
Posted : 08/01/2023 8:41 pm
Page 6 / 6
